DC Offset using the PCI-MIO-16E-1
Hello, I have a question concerning sampling an analog signal using the
PCI-MIO-16E-1. There appears to be a dc offset present when I sample an
analog signal. My input signal does not have a dc offset, so I believe that
the PCI-MIO-16E-1 card must insert some dc offset.
For example if I insert a sine wave with zero dc offset with a peak to peak
voltage of 4 volts, the labview display will show the sine wave from 0
volts to 4 volts, but my oscilloscope show -2 volts to +2 volts. Can anyone
tell me why this happens.
thanks,
joe
(2,808 Views)
First of all check that your analog inputs are configured as Referenced Single Ended and not as Differential. (Use the Measurement and Automation explorer and check Analog inputs settings.)
(2,808 Views)
No need to respond to my post, I solved the problem. You need to program the
board for non-reference input.
Joe wrote in message <9e2914$ijs$1@delphi.ridgenet.net>...
>thanks,
>joe
(2,808 Views)
