DC voltage sources
I am generally interested in Agilent Technologies' Voltage Sources
or Function
Generators (for use as improvised voltage sources). I currently
have the
HP6632A in my experimental setup.I have installed and tested this
instrument's
drivers over a PCMCIA/GPIB interface on a machine running LabVIEW
6.0.
My goal is to use the instrument (HP6632A etc) as a low injection
current
DC voltage source. Specifically, stepping over a range, say -1.5 V
to 2.0 V, at
fixed increments; say 100 mV, and at a set time interval.
Anyone with experience/ideas with regard to this?
Andrew
(2,803 Views)
I gave a simple example to one of your previous posts that shows how to do an increment using a shift register. All you have to do it is add the VI that programs the DC supply and wire the string that is the voltage setting.
(2,803 Views)
