06-20-2008
12:13 PM
- last edited on
06-17-2026
08:22 AM
by
Content Cleaner
I'm running LabView Evaluation 8.5, and my Instrument I/O Assistant was not working (the error message said that I have to use the Driver CD to install the Assistant).
I found the Driver CD online (NI Device Drivers 20007.08) and downloaded it. But when I extract the EXE, I get the error message:
"ZIP damaged: file C:\National Instru.... Possible Cause: file trasfer error."
(See the attached image for the error dialog)
What could be cause of this and how do I install the Instrument I/O Assistant?
Thank you,
Alex
06-23-2008 11:49 AM
06-24-2008
06:17 AM
- last edited on
06-17-2026
08:22 AM
by
Content Cleaner
Hi Alex,
After you installed the evaluation version of LabVIEW 8.5 did you install the DAQmx 8.7 driver? If not, you need to download it and install it. I'm not sure why you are getting the download error, but in any case, that device driver CD has more then what you need. This will automatically install NI-VISA and 488.2 as well as NI-Serial. There are the drivers you will need to Instrument I/O. Thanks.
06-24-2008 08:22 AM
