DCS Upgrade from version 7.1 to 8.5 with Issues
After upgrading to 8.5 from 7.1 I had to change VIs to remove the old DSC Status VI and to replace the old DSC Write with DS Writes. However, the SCF migrate has an issue with finding the "National Instruments.DaqOpc", which is visible in the Server Explorer. In addition, when I try to run the VIs I get the "1184" error associated with the DS Writes and the 1967362040 error with the old DSC Datalogging Start.
Any help?
Message 1 of 9
(3,829 Views)
For error 1184,Check your firewall status.Is it blocking UR communication?
Message 2 of 9
(3,818 Views)
Data Socket and Data Socket Server are allowed through the firewall.
Message 3 of 9
(3,802 Views)
Hi tug,
You might look into this KnolegeBase for a solution to your error 1148:
Error 66/1148 When Writing to a Shared Variable Using DataSocket
Also note that the  DAQ OPC (thats the National Instruments.DaqOpc object) will only be available with Traditional DAQ. If you install Traditional DAQ from the web site, you should be able to work with that object again.
Asa Kirby
CompactRIO Product Marketing Manager
________________
Sail Fast!
Message 4 of 9
(3,761 Views)
Hi tug, Can you tell us what os u r using?
Message 5 of 9
(3,740 Views)
The OS is XP Pro.
Message 6 of 9
(3,718 Views)
Hi Tug,
Did you ensure that you have no spaces in your string inputs to the datasocket VIs (or that you dont use string inputs?)
Asa Kirby
________________
Sail Fast!
Message 7 of 9
(3,700 Views)
Yes, there are no spaces, just dashes and underscores. I am reusing the shared variable constant and not the string constant for the reference.
Message 8 of 9
(3,671 Views)
Make sure that your variables are deployed, or that they are being autodeployed when the VI starts. Also, ensure that traditional DAQ is installed correctly. You might also take a  look at the "Variable Manager" in the National Instruments program group. Look there to ensure that your variables are being deployed correctly.
Asa Kirby
________________
Sail Fast!
Message 9 of 9
(3,650 Views)
