DDT and Waveform Mismatch
All,
    So I was trying to track down a bug in my code, and I noticed this.
    As you can see the DDT and contained Waveform have different timestamps. Does this usually happen? When I convert this from a DDT to a waveform it takes the timestamp attached to the waveform for obvious reasons. Is there any way to extract the DDT information using cluster functions or something so that I can manually repair the Waveform TS?
Ken
(2,719 Views)
Hi Ken,
    Can you attach a simple version of your code that demonstrates this, so I can take a look at the block diagram?
Jim M
(2,698 Views)
