DE FPGA Board not Connecting
I am using DE FPGA board with NI ELVIS II, and LabVIEW 2012. I have searched in the Discussion forum and got the latest driver software (5.2) for the board.
But when I start running my FPGA VI , after successful compilation and generation of Bit file (after synthesis) the error message shows "Communication cable is not detected
What is the problem?
** My board is working fine with Xilinx ISE.
(3,382 Views)
When the FPGA board is connected and powered on, do you see a "Programming cable" listed in the Windows Device Manager?
(3,323 Views)
Thanks for your reply,
But I have already got the problem solved. Smiley Happy
I don't know how, but one day It suddenly worked!! Smiley Surprised then I tried the same procedure in another computer, there also it worked. Smiley Very Happy
I think, the problem was that, the previous version of driver was installed in my laptop, after I have uninstalled it, the device worked!! I am really surprised with the procedure !! But It happened !!
(3,310 Views)
Good, I am glad. One thing that catches people sometimes is if they have the cable plugged in when they install the drivers as they don't install properly when the cable is present
(3,300 Views)
