DFT not Displaying well using Mathsript with IMAQ display
I am using Mathscript to generate a rectangular shape and finding the DFT. The result is been displayed on IMAQ.
The image generation worked fine, but the DFT display is not showing properly, I have to look very closely to see a faint picture. However the same code on MATLAB gives me the display very sharply. Even when I multiplied the final display output i.e by say 30, it shows the image, but not very well, for instance , I could not see the sinc like shape.
I have attached the VI in version 8,5 and 8.0, and also the correct picture I am suppose to get in .jpg.
Thank you
(2,739 Views)
Hi, It 's the same problem you posted last time. Vision Image control is to show the images. When you set the type to U8, it means that 0 is black and 255 is white. However, all you calculate is < 10. So the image control shows black.
In your use case, I recommend you to use "Intensity Graph". It can map your value to the whole color bar. The step is:
1. place a "Intensity Graph";
2. wire your output to "Intensity Graph";
3. Right click on Intensity Graph and set Z scale to autoscale.
Thanks.
(2,720 Views)
