DGPS(VBOX) of racelogic programming
i am using VBOX DGPS of racelogic and I am able to read DGPS data in Byte array form but I m not able to convert this data into desired format. Plz. any body have any coding plz. mail me
Thanku
(4,386 Views)
Hi, alam_nagar.
I'm not familiar with VBOX DGPS. Can you tell me a little more about how you'd like your data to end up? Once you know what kind of data you ultimately need, I recommend using the function search to explore the VIs that handle data in byte form:
Let me know how it goes! Have a nice evening.
Message Edited by sarahk on 08-14-2006 05:02 PM
Sarah K.
Search PME
(4,377 Views)
I know it's been over 16 years since the original post was created, but maybe the attached code can help someone.
The code is in LabVIEW 2020 SP1 and is for the VBOXII serial data.
How to decode the data is given here:
http://www.racelogic.co.uk/_downloads/vbox/Application_Notes/VBOXII_rs232_Format.pdf
(2,056 Views)
