DIAdem data representation
Dear all!!
I would be very pleased if somebody could help me with this fact.
I used labview to write some data from a physical channel in a tdms file and when opening it with DIAdem, although the stored signal is waveform like(not numeric), the x axis units are samples. Is there any possibility to replace these samples by time units?
Thank you very much in advance,
Miren
(2,923 Views)
Hi Miren,
     You may find helpful the following KnowledgeBase. You can also try what is suggested in the following link.
Hope it helps,
David Oña
(2,907 Views)
Thank you very much for your answer. It was very helpful.
Best Regards,
Miren
(2,898 Views)
