DIAdem install from Developer Suite
Hi
I have LabVIEW 8.2 Developer suite and DIAdem is on the list of included software if i am reading things correctly.  I wish to install DIAdem but do not want to re-install LabVIEW and risk upsetting my test platform.  Hence i tried looking for the DIAdem Installer from the LabVIEW CD's but cant find it on any of them.  Is there a way to Install DIAdem from the developer suite without having to go through the "Install LabVIEW 8.5 --> Select components to Install" route?
Craig
LabVIEW 2012
(3,497 Views)
(3,494 Views)
DIAdem is not part of the core Developer's Suite.  It is an add-on pack, which is called the "Data Management Option".  So, if you have purchased this option in addition to the Developer's Suite core, you may not have recieved your discs by mistake.  This happened to me this round, and I am still waiting for my DIAdem disc.
On the other hand, if you have not purchased the Data Management Option, then downloading the file from the previous post will not help, becasue you will not be able to activate it with your DS Core serial number.  Of course I think you would still be able to use it under the 30-day trial.
(3,492 Views)
Thanks For the posts,
I think i will install the above link and try my Developer Suite Serial number as i cannot remember quite what we ordered.
Thanks again
Craig
LabVIEW 2012
(3,481 Views)
To check what you have purchased, go here: http://ohm.ni.com/advisors/devsuite
Click on the tab that says "Existing Developer Suite Customer", then enter your serial number.  It will then tell you your current configuration and give you the prices for upgrades.
(3,474 Views)
