DIAdem path/config for Export to DIAdem
I recently discovered that my "Export to DIAdem" function was non-functional. It doesn't open DIAdem. Export to Clipboard and Excel work fine.
My guess is this is because I previously had DIAdem 2015 installed, and have recently uninstalled it. I had a working copy of 2017 already installed and thought, great - now lets clear up some software I don't use.
Is there a path specified somewhere that gives LabVIEW the DIAdem executable/script to call? This occurs in both LabVIEW 2017 and 2016 on two computers (both of which have recently had DIAdem 2015 uninstalled, and both of which are running Win 10 Pro 64-bit, if it matters).
If I copy to clipboard from a graph, it will happily paste into DIAdem. I'm just curious as to how I broke the direct export, and how I can fix it. If the answer is 'reinstall everything', I probably won't, because it doesn't bother me enough to justify that amount of effort, but at least then I'll know what I can try when bored. If there is some 'repair' installation or similar option for DIAdem 2017, I couldn't find it - please enlighten me!
GCentral
Message 1 of 1
(2,412 Views)
