DIGITAL SIGNAL PROCESSING
Solve this problem please regarding adjoint matrix
(8,053 Views)
antu still has problems with the keyboard...
Hi antu,
for your question: What should we solve here?
- Should we explain how to use MS Word when you just provide a "doc" file?
- Or should we explain how to attach screenshots as "real" picture to the forum?
- Or should we explain to you, that for problem solving you should provide the VI and a proper description of the problem? (Description means provide input data, tell us the expected output data, ...)
- Should we also explain why it is important to stick with it's thread when the topic doesn't change?
(8,041 Views)
Antu13,
impertinent guys like you really make me sick.
Cheers
Edgar
(8,029 Views)
I have already send the example in doc file because when I am going to attach the VI file, it shows "The contents of the attachment doesn't match its file type."
so if you kindly solve this problem first then I will go to my actual problem.
(8,023 Views)
put the VI into a ZIP file...
(8,020 Views)
Thanx for your reply, I have attached the zip folder herewith
(8,005 Views)
Hi antu,
all you need to do now is to define "this problem"...
You have created a VI that calculates a matrix, but you also need to say which algorithm you want to implement and what is the expected output!
Btw.
- why did you create those "0" enums instead of using the ones expected by those matrix functions?
- when you calculate some complex numbers you should also use appropriate indicators instead of forcing them into a DBL display...
(7,994 Views)
