DIO Bit waveform, can the bit width to be 330us ?
I am using a PCI-6251 DAQ card, And i want to use the digital IO of this card to generate a square bit waveforum ,the bit width is required to be 330us+/- 1 %, is it possible ?show me some vi examples if possible .thanks a lot .
(2,494 Views)
Search for pulse train generation in the Labview  examples for 6251. U can use counter for the same to generate the accurate waveform.
You can also use digital waveform generation.vi
(2,463 Views)
