DIO Signal
I would like to verify if my digital input get out of the mask created as is shown in the "Client Interface", my problem that I can't see my DI on the graph.
I will be thankful if someone help me
Thank you in advance
My kind regards
(2,787 Views)
Accepted by topic author k.nadia
You only have 1 point.  Of course you aren't going to see that.  You need to save your Y values in a shift register and build up your array.  Or use a FOR loop to read X samples and then display the waveform.
(2,772 Views)
