DIO6533/AT-DIO-32HS
I would like to know if anyone can help with this problem. NI tech
support has flat out not answered my questions. Their "solutions"
haven't worked either. I want to try this before I pay them more money
for a service contract.
I had been using various applications that used the "Call Library
Function VI" to access NI-DAQ functions in the nidaq32.dll. It worked
great until we started upgrading to LabVIEW 5.0.1f1 and 5.1. Has anybody
else had problems with NI-DAQ functions when upgrading LabVIEW?
Here are some details: an example application first configures the
AT-DIO-32HS using Init_DA_Brds, DIG_Grp_Config, DIG_Block_PG_Config, and
DIG_Trigger_Config in that order. This sets up the board for pattern
generation, input, on group 1, ports 0 and 1, with a start trigger on
ACK1, with an internal clock on REQ1. (DIG_Grp_Config is called again to
un-configure group 2 so that port 4 pin 3 can be used as an output.)
After the board is configured I loop data capture using DIG_Block_In,
DIG_Out_Line (for the trigger on port 4 pin 3), and the DIG_Block_Check
is in a while loop to make sure the data capture is finished before
continuing.
This worked great on LabVIEW 5.0 or older.
When machines were upgraded to 5.0.1 or newer here is an example of what
went wrong:
On LabVIEW 5.0.1f1, if DIG_Block_In was set to read 8192 vectors, it
would read a seemingly random number instead such as 4000 and then stop
(resulting in an endless while loop from DIG_Block_Check). When I forced
the while loop and looked at the 4000 vectors, the first 2000 would be
zeros, and the second 2000 would be accurate. This problem was fixed by
installing an older version of NI-DAQ (6.0.0 instead of 6.1.0 ?).
On LabVIEW 5.1, the data capture works only if the configure is repeated
everytime. If the config is only done once, the second data capture does
the above. That was fixed by running the config everytime but it is not
a good fix because it wastes too much time.
LabVIEW 5.1 seems to have other problems like a memory leak and
sometimes when I click FILE -> OPEN nothing happens. The memory leak
takes a whole system reboot to fix, the FILE OPEN gets fixed after
re-starting LabVIEW. But one thing at a time I guess.
Can anyone help with this?
Thanks in advance - Mike
Sent via Deja.com http://www.deja.com/
Share what you know. Learn what you don't.
Message 1 of 1
(4,830 Views)
