DLL C# Labview
How create a DLL (visual c#) for use witch LabVIEW ?
Is possible or not ?
using System;
using System.Collections.Generic;
using System.Text;
namespace dlltest
     public  class Adder
        public static int add(int x, int y)
            return (x + y);
I would like use method add in LabVIEW
(2,711 Views)
English version of this post: http://forums.ni.com/t5/Discussions-de-produit-de-NI/c-DLL-et-Labview/m-p/1508782
Are you asking if it's possible to create a .NET assembly in C#?   Yes. Note that in C# you'd be creating .NET assemblies, not DLLs.
Are you asking if it's possible to call .NET assemblies in LabVIEW?   Yes - you'd use the .NET functions in the Connectivity -> .NET palette.  Examples are provided in LabVIEW, as well as on this site. A search will yield lots of examples. You did try a search before posting, right?
(2,708 Views)
