DLL Call doesn't work the second time
The first time I open the VI, it runs properly. If I close and open it without exiting LabView, the VI isn’t executable anymore because of the broken arrow. I get the message, Call Library Function: function not found in library. In the DLL I can find and select this function, but it doesn’t run. I’m using LV 6.0.
Does anyone have an idea ?
(3,051 Views)
Hi Dobi,
Try doing a close before you try the open a second time.
Ben
(3,051 Views)
I tried it your way and got error.
I added a close and did not get the error and second attempt.
Did you try closisng?
Ben
(3,051 Views)
Dobi,
The .dll does not appear to be re-entrant.
You have to do a close before doing another open.
Ben
(3,051 Views)
