DLL Calling Conventions, Need Help
Hey everyone,
need some help here...
How do I setup the 'call library function node' for a function in a dll which is called as such:
(in C)  bool get_dxdy_pos (signed short * pDXManual, signed short * pDYManual);
I'm not sure how I pass a pointer in labview, and as for the bool return I can just use an unsigned short int right?
(3,223 Views)
Hi IEC,
As attachement you will find how the setup should be in LabVIEW, hope this helps
Christian
(3,217 Views)
Sorry, I meant to ask what do I connect to the block terminals?  If it's a pointer, can I connect a control? or what?
thanks
(3,210 Views)
Whether it is a pointer or not, first af all the setup of the call library node function must be done, and if you want to pass a value
to the dll, you can connect a control, if you get a value from the dll, you will become a indicator.
You will find a lot of examples at ...\National Instruments\LabVIEWx.x\examples\dll
Christian
(3,196 Views)
