DLL Generation Failure
Essentially I was not being able to generate a .dll file
using Mathwors Real Time Workshop.
I  was able to run the build process in Mathworks and get to the
message:
### Successful completion of Real-Time Workshop build procedure for model:
NEWSineWaveSIT.
However, even though I do this, I have two issues:
1) I cannot find any .dll file in the directory
2) I have a question about the configuration of the build process. Should Icheck or uncheck the "Generate Makefile" Option on the Real Time Workshop tab of the Configuration Parameters? Mathworks said they guess I should have it unchecked, but to ask someone from NI to be sure.
When I check the box it gives me back an error which just says:
Error(s) encountered while building model "NEWSineWaveSIT"
When I unchecked the box, I got this:
## SIT 2009 Modifying NEWSineWaveSIT.c file
Warning:  Unknown data type.  Constructor is "void"
Warning:  Unknown data type.  Constructor is "enum"
## SIT 2009 Modifying NEWSineWaveSIT.h file
## SIT 2009 Generating Ports Readme file
Could Not Find C:\Temp\newsinewavesit_nidll_
rtw\*.obj
### Creating project marker file: rtw_proj.tmw
NEWSineWaveSIT
Does anyone have any idea of what could be causing this? I have attached Pictures of the model I want to convert to dll and how I have configured the Real Time Workshop window.
Eduardo
Message 1 of 1
(2,696 Views)
