I created a DLL with LV 6.0.2. A function in this DLL uses the "Open Serial Driver.vi".
I created an application with MS VC++ 6 which calls this function. Then I get a MSG Box with the above mentioned error and the application exits. I have the EXE, the DLL and serpdrv in the same directory.
I'm running windows NT4.0 SP5/6 german and english versions. The serpdrv is from 2000/06/20.
One the same machines I have also LV 5.0.1 and LV 5.1.1 installed. I hope there will be no cross impacts for my problem.
The KB Article 203EA3XC doesn't answer the question, because "Open serial driver.vi" is delivered from NI with LabVIE
W 6.x.
Calling the DLL functions from LabVIEW will work fine.
Waldemar
Using 7.1.1, 8.5.1, 8.6.1, 2009 on XP and RT
Don't forget to give Kudos to good answers and/or questions
