DLL created by LabVIEW 8.2 doesn't work in VB.NET 2005.
I don't know what I am doing wrong here: I have a numeric indicator as a output, I have done as your documentation says, but I get Exception when I calling
the dll .
Here the VB program:
Visual Basic 2005 program:
'long __stdcall Snap(char Path[]);/////////This is the function protype.
Imports System
Imports System.Runtime.InteropServices
Imports System.Windows.Forms
Imports System.Threading
Public Class Form1
    Private StopAcquire As Boolean = True
    'This function definition was found from the header file of
    'GrapImage.dll, which is built in LabVIEW
    <DllImport("Snap.dll", EntryPoint:="Snap", _
     CharSet:=CharSet.Auto, CallingConvention:=CallingConvention.StdCall)> _
    Public Shared Function Snap(ByRef Path As String)As Int32
    End Function
    Private Sub Form1_Load(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles MyBase.Load
        MsgBox("welcome to use 2005 and LabVIEW!", MsgBoxStyle.OkOnly + MsgBoxStyle.Information, "NI")
    End Sub
    Private Sub Button1_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button1.Click
        Dim Picture_Addr As String= "E:\MyPicture.bmp"
        Dim camera_Num As Int32
        StopAcquire = False
        While StopAcquire = False
            camera_Num = Snap(Picture_Addr)       '///////////////////  Exception Occurred!----- "Can't load DLL "Snap.dll":Can't find the appointed module(Exception come from HRESULT:0x8007007E)
            PictureBox1.Load(Picture_Addr)
            Label1.Text = "Totally have" + camera_Num.ToString + "USB Cameras。"
            Thread.Sleep(2000)
        End While
    End Sub
    Private Sub Button2_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button2.Click
        StopAcquire = True
    End Sub
End Class
Striving is without limit!
(3,401 Views)
You really should keep all correspondence on the same issue on the same thread.  That is good forum ettiquette.  Please continue in this thread.
I am sorry but I don't have any more information that could help you.
(3,386 Views)
Anyway,I aggre with you opinion,I'll will be careful later,But this issue is different with that.The exception is a new one and previous exception haven't occurred.
(3,380 Views)
