Showing results forĀ
Search instead forĀ
Did you mean:Ā
DLL file problem in Labview 8.5
Thank you all for trying to help me with dll issue.
I tryied to run the borland c++ example which uses the same dll and it worked just fine.
The problem is that when i try to run the same dll with the labview example the call back library outputs the wrong number.
I think that this LV example was developed in the 7.0 or 7.1 version whyle i'm using the 8.2 version.
i was wandering if there is any chance that might be the cause of all problems? s ther any way to chek it ?
Message 11 of 18
(1,812 Views)
From the information you have provided so far it is really difficult to determine what might be causing this problem. If you post your DLL (and source code if possible) and your VI, we might be able to reproduce the issue and figure out what the problem is.
Eli S.
Message 12 of 18
(1,797 Views)
how to open a dll file of iir cascaded filter  which is a inbuilt icon in lab view
kindly reply
Message 13 of 18
(1,524 Views)
Hi rashu,
I'm sorry but I'm having trouble understanding what you are asking, are these IIR Filtering VIs the functions you are asking about?
http://zone.ni.com/reference/en-XX/help/371361E-01/lvanls/advanced_iir_filtering/
Peter W.
Message 14 of 18
(1,509 Views)
s sir,, the same what u told,, cascaded IIR filter. the same,,
in that internal  blockdiagram of cascaded iir filter there is a DLL file,, how to know whats inside that DLL file,,
kindly reply
waiting for u r reply
Message 15 of 18
(1,500 Views)
Hi rashu,
The IIR Cascade Filter (DBL).vi uses a Call Library Function Node to call lvanlys.dll, which is found in C:\Program Files\National Instruments\LabVIEW 2010\resource\lvanlys.dll. As far as what is inside of the DLL I don't have that information, but the function that the program calls is IIR_Filter2.
Peter W.
Message 16 of 18
(1,489 Views)
dear sir,,
then how can i will know ,, how does that work,,
its very important for my project to know,, how does it filtrs the distorted signal, using the  fwd and rev coefficients.
can u plz guide me,,
i have tried all possible way,, but could not get it
Message 17 of 18
(1,485 Views)
Hi rashu,
As far as understanding how the functions work I would refer to the help topic I linked above for the Advanced IIR Filtering VIs. That will give you all of the information that is avaiable on the filtering process they use.
Peter W.
Message 18 of 18
(1,474 Views)
