DLL running error without admin right in win7
I am using LV to call one dll in win7. Only if I run LV8.6 up with admin right, and then call the dll, the dll can work all right.
May you give any suggestion, thanks.
(2,437 Views)
1. If you use lower version or without administrative, what will happen?
2. What is the suggestion you want? How can I run it without administration privilage?
3. Have you check your dll whether it needs to run some function with administrative privilage? If it is, you need to fix this dll.
4. Only LV 2009 or later support Windows 7. You may find some un expecterd behavior with lower version.
(2,419 Views)
