DMA FIFOs support the U32 integer data type
I am using Labview 8.6 with CRIO 9014. Do DMA FIFO support U32 integer types only? Do i have to convert fixed point data i am getting from NI 9215 module to u32 before i input data to DMA FIFO write function?
(3,700 Views)
Hi suni,
some crios support also other DMA types. If yours dosn't support it, then see this link please. There you see how to transform fixed point to u32 and back.
Mike
(3,675 Views)
Are you not able to select FXP as the data type when you create your FIFO?
(3,649 Views)
I was able to select FXP in the module. Thanks.
(3,621 Views)
Also in the DMA FIFO I was able to select FXP type. Thanks
(3,620 Views)
