DMA fifo
HI all,
  is there any number limitation when using DMA FIFO in a Compact Rio FPGA.
SASA
(4,586 Views)
Hi SASA,
yes, there is.
Spoiler
The number of FIFOs is limited, smaller cRIOs only support 3 of them…
(4,579 Views)
thank you!
(4,563 Views)
Hi saketa,
are you working in the same group with SASA? Or are you the very same person with two different user accounts?
Your topics/questions in the forum are very much the same…
(4,560 Views)
Hi GerdW,
     yes we are the same,
     retreiving our discussion, what is the limitation for CRio 9068.
SASA
(4,553 Views)
Hi SASA/saketa,
sometimes a little Google search for "crio 9068 fifo" is all you need: the solution was the first search result…
(4,549 Views)
