DMM RMT mode won't stop
Hi All,
I Run the simple Labview program before. After then the Keithley 2100 DMM turned to RMT mode automatically every time after power cycle. Is there any way that I could stop it?
Thanks a lot!
(5,149 Views)
Hi Mona,
this seems to be a problem with your Keithley2100 DMM - maybe you should read its manual to find the answer?
(5,135 Views)
After plug out the USB cable from DMM, it works. But Once Plug in the USB cable, the DMM turns to RMT mode. Is there any possibility that it is because of my Labview Program which keeps it in RMT mode?
Thanks a lot!
(5,131 Views)
Hi Mona,
Well, surely there is a possibility - even when it is very low!
How can I tell you when you don't provide your LabVIEW VI?
I don't know what your VI does nor do I know the commands you use.
And I don't know the exact behaviour of your DMM: that's why I suggested you to read the manual…
(5,128 Views)
