DMM multipoint measurement
I have a PXI-2575 switch and a PXI-4070 DMM. I have to measure 156 outputs, which give in ascending order two pulses, approximately 75ms wide and 400 to 800 ms apart.
Is it a good idea to use the DMM and niSwitch DMM Switch Handshaking.vi for this ? The problem with this is that you have only measurement points and no waveform data,
where you can do waveform analysis on. Is it better to use a PXI-5105 digitizer for waveform analysis ?
Message 1 of 1
(2,963 Views)
