DMX-512 driver/code
I would like to build a program to control DMX-512 systems.
Is there any experience with this protocol in LabVIEW?
Are there any drivers or VIs available somewhere?
Thanks in advance.
Gr, Jan van den Eijnden
(6,879 Views)
Hi Jan,
I'm not aware of any DMX-512 interfaces that come with a LabVIEW API. However, most of those interfaces come as PCI cards or as serial-to-DMX512 converters.
In the first case, there is always a DLL to communicate with the PCI card and you can use LabVIEWs Call Library Node to call that DLL from your LabVIEW code.
Quite a few DMX-512 converters are connected through RS232 (or RS485) and LabVIEW as built-in support for the serial port. This seems to be the easiest approach.
Good luck!
Einstein
(6,862 Views)
I agree with Einstein,
Easiest way would be to connect to the built-in Serial port on the cRIO to connect to a rs232/dmx512 converter, and then simply use VISA commands to communicate.
I am no pro on the DMX512 protocol, but I suppose it is possible to create your own custom drivers through the FPGA interface, but you would really have to know what you are doing.
Rob K
Measurements Mechanical Engineer (C-Series, USB X-Series)
CompactRIO Developers Guide
CompactRIO Out of the Box Video
(6,568 Views)
