DNP3
We are making a new test system using TestStand.  We have custom steps that need to talk to our unit via DNP3 but using a slightly modified application layer.  Has anyone done this before?  Can the DNP3 driver be used on a host PC to interrogate a slave unit?
(4,324 Views)
It might be more effective to post this question on the TestStand forum.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(4,301 Views)
Accepted by topic author at2bob
You can move this discussion in Teststand fourms.
We have developed DNP3 CSTs using TMW. Yes you can use DNP3 drivers on Host PC as a server and Your device will be slave unit.
Thanks and Regards
Himanshu Goyal | LabVIEW Engineer- Power System Automation
Values that steer us ahead: Passion | Innovation | Ambition | Diligence | Teamwork
It Only gets BETTER!!!
(4,294 Views)
Can anyone who has worked on NI Industrial comm for DNP3 can let me know whether the NI drivers for NI Industrial comm can be customized?
Navya.
(4,245 Views)
Duplicate: http://forums.ni.com/t5/LabVIEW/DNP3/m-p/2556009#M772890
If you have more Industrial Communications questions, you can try the industrial communications forums.
http://forums.ni.com/t5/Industrial-Communications/bd-p/260
-KP
Kurt P
Automated Test Software R&D
(4,197 Views)
