DO task randomly stops (no errors generated)
Attached is a simple little VI that generates a digital waveform and outputs it to the one of the DO pins.
For this example, it is a 50 kHz digital signal.  If I let this VI run, it will just stop randomly and without any error.
This appears to happen randomly.
I am using LabVIEW 2011 and DAQmx 9.3.5 using a NI-USB-6366.
http://www.medicollector.com
Message 1 of 31
(5,605 Views)
To elaborate:
The problem is that it stops generating output after a random amount of time.  But the VI doesn't stop executing, nor does it generate an error.
Btw:  This issue appeared to start hapenning when I switched from a USB-6361 to a USB-6366.
Message 2 of 31
(5,595 Views)
I did verify that I see a roll over at 4.29 G with USB X Series as well.  I'll give your VI a go and see if I can reproduce the stopping behavior you see.
Dan
Edit: Got threads mixed up.  Roll over is in reference to this.
Message 3 of 31
(5,583 Views)
Just ran the same code on my 6361 and it doesn't seem to freeze up.  Though I should let it run for a longer period of time.
I have a suspicion it only happens on the 6366.
Message 4 of 31
(5,575 Views)
If you put a wait in the while loop, does it still stop randomly?
Message 5 of 31
(5,571 Views)
Yeah, adding a 100 ms wait to each iteration does not seem to have any effect.
In fact, if you try the attached VI, which outputs a 10 MHz digital signal, my USB-6366 almost immediately freezes up.
But my USB-6361 doesn't freeze up at all.
Message 6 of 31
(5,567 Views)
Whoops.  My bad.
This error actually DOES occur on both my USB devices:
USB-6351
USB-6366
But does NOT occur on my PCIe device (PCIe-6363).
Am I doing something wrong here?  Can't seem to ouput a 10 MHz signal?
Message 7 of 31
(5,562 Views)
Btw:  I am also getting a similarly strange behaviour on my AI tasks.  Just freeze up and stop returning any data.  I'll see if I can isolate that issue, too.
Message 8 of 31
(5,559 Views)
Can you put a DAQmx Is Task Done.vi in your loop?  I don't necessarily know that reading a write status property would return an error if one were to occur.
Dan
Message 9 of 31
(5,553 Views)
any chance you are running on an old machine with USB version 1 as aposed to USB 2.0 that added... were they pipes?
Ben
Message 10 of 31
(5,545 Views)
