DPO 4054 force trigger event
I have a Tektronix DPO 4054 O-Scope, connected to computer with USB, running LabView 2013 with tkdpo4K drive s/w, I'm trying to force a trigger event with labview. I'm not seeing a trigger vi that I can use, also I refereced the dpo-4000series programmer manual and sent a TRIGger VISA command as stated on page 2-49 of the manual that did not work either.
(3,879 Views)
Accepted by topic author Tronman
I was able to perform trigger event with the following command *TRG;
I also found better driver software "Tektronix DPO MSO 2000 4000 Series"
(3,820 Views)
