11-25-2025 08:51 PM - edited 11-25-2025 09:10 PM
11-26-2025 01:30 PM
It looks like if "Start Module.vi" leaves memory the counter will be reset. "Called through a file path" tells me you may be opening a reference to "Start Module.vi" by path. If so are you closing the reference after each clone is launched? If so try leaving the VI reference open instead.
11-27-2025 02:58 AM
this way good,i did not try your method,
