DRAM from FPGA badly written at application start
hi! I have a strange behaviour with my LabviewFPGA code joined in ZIp file (LV2019)
At program start, is to be automatically configured a DRAM signal with a 100k points at init
the problem: if I launch the main RT (RT test intersectif.vi in the zip file) once after compactrio power supply ON, the DRAM is not configured correctly, and I get noise (below) 
if I try again to run the VI, the signal becomes correct.
everytime I get 1st run time NOK and the 2nd one OK, whetever the time I wait between power ON and 1st start
I absolutely need this signal DRAM to be correctly uploaded at start.
Is there something wrong in my code?
thanks in advance for the help
Pierre FCentum TNS, Grenoble
Certified LabVIEW Associated Developer
(909 Views)
DRAM handshaking is not connected fully
Certified LabVIEW Architect, Certified Professional Instructor
ALE Consultants
Introduction to LabVIEW FPGA for RF, Radar, and Electronic Warfare Applications
(830 Views)
