DRIVER - NI-INSTRUMENT SIMULATOR 2.0
In device manager my simulator has no driver
I try to search the CD that came with and nothing
I try to search the download i got from NI and nothing
I can not configure with the wizard
Message 1 of 9
(1,444 Views)
I also tried the Driver Finder
when selecting start using this driver it showed
I went back and installed the next one nidevsim_2.0 Instrument driver
i checked device manager and ni max which both said my device had no driver
with device manager i tried searching
C:\Program Files (x86)\National Instruments\LabVIEW 2015\instr.lib\NI Instrument Simulator
which was just installed and got nothing (same for search atomically for drivers)
i went back to driver finder and said install to overwrite existing files
repeated the process searching with device manager and still nothing
can someone help with what I need to do to use this device?
Message 2 of 9
(1,399 Views)
I wanted to follow up and check if I have this posted to the correct area?
Message 3 of 9
(1,369 Views)
any suggestions to try would be welcome
Message 4 of 9
(1,322 Views)
following up again
Message 5 of 9
(1,281 Views)
Accepted by topic author cwhw112
Maybe you just need the GPIB driver?  I don't know a lot about NI Simulation but here is the GPIB driver.
NI-488.2 Download - NI
CLA
Message 6 of 9
(1,263 Views)
Should I get the latest or closest to my labVIEW version?
Message 7 of 9
(1,253 Views)
Driver support is for the matching LabVIEW version plus the 3 before it.
So if you are using LabVIEW 2021 through 2024, you can get the 2024 GPIB drivers.
But if you're using LabVIEW 2015, which is my best guess based on screenshots, then you want to get the drivers from no later than 2018.
Message 8 of 9
(1,247 Views)
(sorry for the delay)
I installed the driver you suggested:
and now it shows up good in device manager
also in NI MAX
and the simulation software sees it
THANK YOU!!!!!!!!
Message 9 of 9
(1,189 Views)
