DS18B20 +Relay +Raspberry pi 4
Hello everyone!
I need help programming a DS18B20 sensor. I would like to activate the relay and block the machine by generating 0 volts when the temperature reaches 25 degrees Celsius. If the temperature is stable, I want the relay to generate 24 volts.
Thanks a lot for your help!
Message 1 of 1
(1,116 Views)
