DS345 Arbitrary waveform VI
Dear all,
I need to build a code in Labview to generate an arbitrary waveform using DS345-Function Generator (from Stanford Research Systems).
I was just wondering if someone here have done that already...since I'm not that good with Labview. That would be very helpful and will save a lot of time.
Alex
(3,688 Views)
Hello Alemns,
The easiest way for you to get your code up and running is to use our Instrument Driver Network, which allows you to search through pre-built LabVIEW  instrument drivers that control a programmable instrument. Within this site you will find not only how to use the instrument drivers with your LabVIEW code, but also the one that is specific to the DS345-Function Generator from Stanford Research Systems. I hope this information proves useful and that you have a great day!
Nicholas K
(3,666 Views)
