DSC 6.1 functions do not work
I've just installed DSC 6.1, and the only selection that opens in the DSC menu is the Image Navigator. Trying to launch any of the other item won't work because they can't find all of their VIs.
Example: I try to start the DSC Toolbar and it searches for lv_SpawnVI.vi. It's suppose to be in vi.lib\extensions\_core\_utils.llb, but the directory "_core" does not exsist.
There's also .llb's missing in "vi.lib\extensions" and "vi.lib\extensions\security" and probably others.
I've uninstalled and reinstalled with no change. Installed the patches available with no change.
Has any one else seen this?
Ed
Ed Dickens - Certified LabVIEW Architect
Lockheed Martin Space
Using the Abort button to stop your VI is like using a tree to stop your car. It works, but there may be consequences.
(3,436 Views)
Hi Ed,
I haven't seen this before. Make sure that you login as Administrator and choose the default path. If uninstalling DSC does not help, uninstall also LabVIEW 6.1 , reboot your PC and install LabVIEW 6.1 and DSC 6.1.
Best Regards,
Remzi A.
Applications Engineering
(3,436 Views)
I got it working. I had to uninstall DSC 6.1 and 7.0, then reinstall 6.1 and everything seems to be there, at least in 6.1. I don't have my 7.0 CD with me to reinstall, so that will have to wait.
Ed
(3,436 Views)
