DSC 8.0 Run-Time custom installation
I'm having the same problem getting executables to find VarXnode.xnode.  When I deselect "Enable Enhanced DSC Run-Time Support" in the Build Specification (Advanced), the executable can find everything, but I lose debugging functionality.  Changing everything to DataSocket doesn't sound appealing.  Any word when the NI fix will ship?
Message 11 of 16
(4,488 Views)
DSC...:
What version of the LabVIEW DSC module are you using?
Rudi N.
Message 12 of 16
(4,469 Views)
Rudi,
8.20
Message 13 of 16
(4,458 Views)
DSC...:
When you do create your executable, do you have the "Enable Debugging" option checked?. At what point of the process do you lose debugging functionalities?. Does your executable appear in the list of applications? If so, at what point of the process do you not have debugging capabilities?. Please let me know what you find.
Rudi N.
Message 14 of 16
(4,421 Views)
Rudi,
The executable was created with "Enable Debugging".
Usually when the application boots up, it starts immediately, but in this case, it loaded in the "stopped" condition.  Debugging was never available in that build, as far as I recall.
I apologize for my ignorance here - which "list of applications" are you referring to?
I have since ripped out the Shared Variables, and replaced them with DataSocket, and now the application loads and runs correctly.
Dick
Message 15 of 16
(4,392 Views)
Dick:
Once you click on Tools >> Debug Application or Shared Library, you get another window that allows you to select the application that you would like to debug. Please let me know if you run into further difficulties with DataSockets.
Rudi N.
Message 16 of 16
(4,348 Views)
