DSC I/O points
Hi guys,
Does LabVIEW DSC Module have a limit of I/O points (tags) that can be used at the same time ?
(3,210 Views)
Hai,
See this
Mathan
(3,199 Views)
(3,197 Views)
Hi metrisys,
The limit will come from your system resources, not LabVIEW DSC.  Your processor speed and system memory will affect performance.  For LabVIEW DSC 8.x, it is recommended you deploy no more than 80,000 shared variables per 1 GB of RAM, as stated here.  If you are logging alarms and events, the maximum size for this data in Citadel is 2 GB.  However, there is no limit to the amount of historical data that can be stored.
Jennifer R.
(3,180 Views)
