DSC Module: Creating a Periodic I/O Server Problem
dear All
I'd like to know how to creat a Periodic I/O Server in the DSC module.
i followed all the steps in the Getting started manual as follows:
  • In the Project Explorer window, right-click a target, such as the My Computer target, and select New»I/O Server from the shortcut menu
    But i don't get anything but the below window listing only the EPICS client
    Message Edited by MAshraf on 04-02-2009 04:57 AM
    Eng. Mohammed Ashraf
    Certified LabVIEW Associated Developer
    InnoVision Systems Founder, RF Test Development Engineer
    www.ivsystems-eg.com
    (3,257 Views)
    Good Afternoon MAshraf,
    It seems that there is something wrong with your DSC Module installation; the list in the Create New I/O Server window should look like the image I attached.
    Did your DSC Module activate properly?  Have you tried doing a repair of the LabVIEW DSC Module?  If the repair does not work, you may have to uninstall and reinstall the DSC Module.  The installation files can be found on DVD 1 of the LabVIEW 8.6 Platform DVD release.  Both the repair and the uninstallation can be done from Windows Add/Remove Programs, found in the Windows Control Panel.  All National Instruments software is listed together in the list of Windows software as "National Instruments Software."
    (3,229 Views)
