DSC Pipe Cross Control
Hello everybody,
has someone created a customized cross-shaped pipe control?
Something like the one in the picture attached. I've tried to modify that in the DSC module but the result isn't so pretty... Smiley Tongue
Thanks for any reply.
(3,391 Views)
Hello BuoNI,
actually I never did it.
You can modify your indicator customizing it; you have to choose an indicator, right click on it, choose customize and then you can also import an external picture.
I hope my answer helped you,
Kind regards.
(3,334 Views)
