DSC- Read trace error -2147467259
Hi
I am using NI DSC module for client application using Citadel Database.
The Citadel works well initially for some days and then it results in error.
I get error - 2147467259 from read trace.vi although the trace is found in database attached to citadel from NI MAX.
The problem persists until I delete the currenrt database and attach a new database.
Following are the software version used
LabVIEW verison - 14
LabVIEW DSC version - 14
Citadel 5
Message 1 of 1
(2,902 Views)
