DSC TAG ENGINE doesn't run after using eval copy of LabView
I used an eval copy of LabView.
I uninstalled this eval copy and I bought and installed the full NI Developer Suite.
Now Labview 6i (6.0) works properly but I'm unable to use DSC because the Tag Engine stops immediately with this message: "This evaluation copy of Labview has expired. Engine will close".
I'm using a Pentium III PC 128Mb RAM Win98 italian version.
(5,639 Views)
Hi Silvano,
I found a similar case from another customer. Nationl Instruments is aware of this issue. But the only workaround for now would be (propre version):
1) uninstall LabVIEW DSC and LabVIEW
2) delete the registry key from the old LabVIEW eval version with regedit.exe.
[HKEY_LOCAL_MACHINE\Software\National Instruments\LabVIEW\lvedid]
3) reinstall LabVIEW and LabVIEW DSC
(short version)
1) Rename lvedid in the:
[HKEY_LOCAL_MACHINE\Software\National Instruments\LabVIEW\lvedid] to e.g. ..\LabVIEW\1lvedid
Hope this helps
Roland
(5,639 Views)
