Showing results forĀ
Search instead forĀ
Did you mean:Ā
DSC for LabView 2023 Q3
I missing the Version  of "LabVIEW Datalogging and Supervisory Control Module" for LabView 2023 Q3, the Version DSA for LV 2023 Q1 won't work if I create a Project with the Modbus vi's.
Does anyone know when this will be available?
(4,917 Views)
Are you using anything else from the DSC Toolkit than the Modbus VIs?
If not I would recommend you to simply download and install the NI Modbus Library with VIPM. It is pretty much the same library as what the DSC Toolkit installs.
Rolf Kalbermatter  My Blog
(4,904 Views)
Thank you for reply.
Unfortunately that's not possible, I work with an external company that develops for us and they tell us what we can use, for Modbus we can only use the DSC.
(4,884 Views)
Then your options are limited:
1) you'll have to wait with upgrading to LabVIEW 2023 Q3 until the DSC Toolkit is available.
And you should also consider a plan B for the future. LabVIEW DSC is most likely never going to be ported to 64-bit. But LabVIEW will in the not so far future be only shipped as 64-bit version.
(4,846 Views)
I downgradet to LabView 2023 Q1 and the Modbus library is now working inside of the project again.
I'll probably have to wait until DSC is available for Q3.
(4,823 Views)
I am facing the same problem right now.
Does anyone now when DCS will be available for LV Q3?
(4,659 Views)
