DSC opc read & BBDD SQL insert with DELAY
Hello everybody,
I have an application which read data via OPC using DSC and it writes every change into a SQL Database. I´m checking in the database the timestamp of the OPC tag and the pctimestamp when the value is written in the databse having a normal delay of 3 sec roughly.
Aparently It doesn´t appear any error but when is running for about 2, 3 days, the delay increases to an hour, that doesnt seem a problem of the virtual memory because it keeps constant.
Few times when I have checked the application It appeared some errors with the ODBC.
I´ve attached the snapshots of the errors and the layout of the application.
I dont know what can be the cause of that delay, so I would appreciate some help about that.
Arnau
(3,095 Views)
just to make sure, I understood you correctly: When the programm starts, you write to the SQL DB, which takes 3 seconds. So the programm takes 3 seconds to execute the VI, right?
After 3 days it takes 1 hour to write to the Database so the programm stops at that point for 1 hour.
Is the increase in the write time gradual or does i go from 3 seconds to 1 hour all of a sudden?
Could you please provide me with the Error numbers? In the Pictures you attached I can't read them completely.
Remember Cunningham's Law
(3,063 Views)
First of all thanks for your time Peter and sorry for my delayed answering your questions.
The 3 seconds delays it came from the subtraction of the Ttimestamp and PCTimestamp. I don´t have the error numbers because I only have the snapshoot, and the delay increases gradually.
I open only one time a database connection so that´s why I dont understand the reason of that acumulative delay.
Arnau Domingo
(3,010 Views)
