DSC
Hi everyone. I have a doubt. If I have running two standalone applications each of which uses the DSC module. Do I need one or two DSC runtime licenses (the version I use is the 2014)?
(3,945 Views)
It sounds like you have a question, not a doubt.
If you have two standalone applications and they are running on the same PC, you only need the one license for a runtime module.
Now if you have applications running on different PC's, then I think you will need a license for each PC.
(3,922 Views)
Thanks! But ... Do you think? or Do you know?
(3,916 Views)
Read the Overview in http://www.ni.com/pdf/manuals/375311a.html
It says "on a computer" and also "applications".
(3,909 Views)
