DSL Speed requirements for Labview
I would like to access my remtoe test stations using the front panels options. what is the required speed for best results?
(3,573 Views)
I don’t know that there’s a “speed requirement” per-se, but the faster the better.  When you connect to the remote front panel, some portion of code is downloaded to your client computer, then the data updates are sent through a protocol based on TCP/IP.  Your title mentions DSL which (at least on my home computer) has pretty good download rates, but much (MUCH) slower upload rates.  If you are serving panels from a DSL machine you might have more problems than if your client machine was a DSL machine.  In either case, I imagine any broadband connection would be just fine.  I do recommend checking with your DSL provider to make sure that serving pages is within the scope of your TOS.
Travis M
LabVIEW R&D
(3,558 Views)
Thank you! I guess we will go with the highest rate the can provide!
Rick
(3,552 Views)
