DSO-5200AUSB's LabVIEW program not running.
Hello, I am trying to work on changing the code to the DSO-5200AUSB oscilliscope. When I try to run the LabVIEW program, I get an error message that the file MFC42D.DLL is not found (but I know that it was installed and I know where it is). I assume the files are supposed to be put into the LabVIEW directory, but I cannot figure out how to do this.
-Dimitri
(2,667 Views)
Hi Dimitri,
Has this program worked before? Also, did you create this program, or did it come with the hardware? Also, what is the current location of the MFC42D.DLL? Did you install the driver for the DSO-5200AUSB oscilliscope?
Sunaina K.
Product Marketing Manager for CompactRIO & TSN
Making the intangible, tangible
(2,652 Views)
