DSP inverse fft problem
Hi otlm,
Are you using a hardware device with this example?  Have you added the VI to a project?  Based on your comment, it seems like you may have done this, but here is a tutorial that talks about adding the VI and the hardware to a LabVIEW project.  Do you get a specific error when you run the VI that triggers some sort of failure?  If you get an error, please post that to the discussion forum.  Thanks!
Kim W.
Message 11 of 12
(673 Views)
I answer the questions in the topic named "DSP FFT problem".
Message 12 of 12
(661 Views)
