DSnewptr address changes after calling dll function cause labview to crash when disposing pointer
Hello, I try to deference 5 float arrays generated and passed from dll.
I use DSnewptr to allocate 5 memory blocks, and each block is set as size of (float) * array length;
All 5 dst arrays can successfully dereference the float values, however, this vi will crash when some of the DSDisposePtr are being called.
I guess it crashes due to the addresses from DSnewptr are somehow modified by my dll function, and wrong address are passed for disposing.
This vi will not crash if I set the "block size"(array length) less equal than 13, and the addresses generated by DSnewptr will not changed by CLFN.
Please help! Thank you.
(1,271 Views)
Accepted by topic author Rediis
The readXindata call library node for the array arguments must be changed to pass by value
(1,226 Views)
The same goes for the src parameter to MoveBlock. The value you have is already a pointer. You are effectively overwriting the pointer address. You can see that in the pictures: the input and output of the sx terminals should stay the same.
(1,214 Views)
Thank you!! It works now!!!!
(1,177 Views)
